Ricoh SP5300 - Paper Lift clicking on a full Paper tray 1 - ok when half full
  • dave w
    • Jun 2015
    • 230
    This may be helpful and some help please
    Customer complaint was a loud clicking noise from the printer.
    Visually all looks fine, No evidence of gear wear on thelift mech.On close inspection the gear had some movement which mademe look at the gear itself by removing it, on removal it was obvious what wasthe cause of the Loud click.
    The post that holds the gear in place has broken away fromthe plastics
    My question is - is there a part number for the plastics that the post is on as the manual is not very helpful
    Thanks in advance
    Dave w
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 589
    Re: Ricoh SP5300 - Paper Lift clicking on a full Paper tray 1 - ok when half full
    [ATTACH=CONFIG]39444[/ATTACH]
    [ATTACH=CONFIG]39445[/ATTACH]
    [ATTACH=CONFIG]39446[/ATTACH]
    Thanks in advance
    Dave w
    Yes the part was added to the parts catalog at the end of last year along with a bulletin for this issue, I will attach the bulletin which also includes the part number.
    rfg077945.pdf
    • dave w
      • Jun 2015
      • 230
      [ATTACH]39447[/ATTACH]
      Many thanks strumtrooper - a propper trooper
      this is why Copytechnet is my Bible.
      BIG thanks again.
      Dave w
