mpc3004 banner prinitng
  • slot
    • Jul 2008
    • 341
  • ridgemill
    • Sep 2017
    • 190
    Re: mpc3004 banner prinitng
    No settings should need to be changed. It does help having the additional banner tray option; but this is only for keeping the paper in the bypass tray, without having someone standing over it watching.
    You will need to specify the bypass tray as the input tray, and use the Custom Paper Size option, under Detailed Settings > Basic.
    • Brianneoe
      • May 2015
      • 318
      Banner printing on the 03 series machines required using the printer only version of the machine because the MFP version did not have the length size in the MFP driver.
      That said, if you can't see the length size needed in the MFP driver, download the printer only driver and call it something like Banner Driver.
      Good luck
        • 37481
        Good luck
        I guess you did not read what ridgemill posted, or at least not the attachments. A banner is not a fixed size of paper. You have to program a custom paper size. If you are going to use the same size frequently, create a "one click preset."
