ricoh mp c5000 has error sc120
  • Mukasa
    • May 2015
    • 178
    Hi Techs
    sorry this machine ricoh mp c5000 has error sc120 , i have tried to check all the toners specially black .
    what can i do.
    godfrey
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh mp c5000 has error sc120
    SC120 - Scanner home position error 1 - The scanner home position sensor does not detect the “OFF” condition during
    operation.
    • Scanner motor driver defective
    • Scanner motor defective
    • Harness between SIO board and scanner motor disconnected
    • Scanner HP sensor defective
    • Harness between SIO and HP sensor disconnected
    1. Check the cable connection between the SIO board and scanner motor.
    2. Check the cable connection between the SIO and HP sensor.
    3. Replace the scanner motor.
    4. Replace the HP sensor.
    Hit it.
    • sandmanmac
      • 3990
      Originally posted by Mukasa
      Hi Techs
      what can i do.
      godfrey
      You've opened 2 separate threads today including this one:
      Ricoh MP 5000 error sc 200
      This thread apparently only started because you indicated the wrong SC in your first one!
      Your only solution has been to check the toners -especially black (for some reason).
      Neither of the issues have ANYTHING to do with toner.
      You obviously have no technical experience, so call a tech.
      • Mukasa
        • May 2015
        • 178
        Thanks , yes i went ahead and checked the scanner ,opened the glass off ,cleaned the sensor and the mirrors .
        When i powered still the scanner carriage doesn't move at all and the lamp doesn't light .
        This error has been on and off for the last one month but this time its permanent .
        i will check the motor tomorrow but if you think of any solution please send it to me .
        Godfrey
          • 37618
          Do you even have a service manual or are you just too lazy to check it?
          • sandmanmac
            • 3990
            Godfrey
            Your solution is 1 of the 4 options listed above!
            How about this....you go ahead and actually do what's been suggested, and get back to us afterwards
            TIP: it's not just a dirty sensor!
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              AND...you cost me a 20.......
              • Wild Bill
                • Jul 2005
                • 774
                I lost a $20.00 also, please pay attention sir!
                Izzy
                  more than likely no manual and NOT a tech!
                  • Mukasa
                    • May 2015
                    • 178
                    thankx
                    am tech for xerox
                    but this machine is working now
                    thanks
                    • fshead
                      • 2378
                      thankx
                      am tech for xerox
                      thanks
                      What and i guess it is too much to share what you did to fix it?
                      I know>>>SWAP out machine with a xerox
