MPC4000
  • GeorgeBest
    • Jul 2009
    • 526
    MPC4000
    HI
    Sometimes this machine gives color strokes as in example.
    Mostley first time running in the morning.
    Can work all day fine, next day the same, even with just black prints.
    Anyone a clue here . .
    Velde.pdf
    Thanks in advance
  • francisco
    • Nov 2009
    • 168
    Re: MPC4000
    Originally posted by GeorgeBest
    HI
    [ATTACH=CONFIG]39460[/ATTACH]
    [ATTACH=CONFIG]39459[/ATTACH]
    Thanks in advance
    bad transfer belt cleaning blade
    • Codex
      • May 2008
      • 704
      Re: MPC4000
      Transfer belt cleaning assy, had a lot of machines with the same problem
      Inviato dal mio SM-G935F utilizzando Tapatalk
      Memento Audere Semper
        • 37490
        Re: MPC4000
        Dirty charge rollers. Often an indication that the PCU needs to be replaced due to lube bar excessively worn. Replace the PCUs and then make the adjustments in the attached.
