Ricoh mp2501 developer on page
  • irokkas
    • Oct 2012
    • 18
    Hello,I have a problem with a Ricoh mp2501.There is developer on the drum and on the printed page.No SC code.
    I installed the PCU to another copier and worked great.Installed another PCU ,the same problem.I have changed the transfer roller , cleaned the laser unit and checked the developer values.Nothing changed.
    Any suggestions would be greatly appreciated.
    Thanks,
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh mp2501 developer on page
    Hi there!
    Take a close Look on the hv-contacts.
    Greetings...
    • limo
      • Jun 2008
      • 101
      check the quenching lamp above the drum
      • LNorris
        • Sep 2008
        • 645
        pull the pcu out and look at where it sits. look for toner underneath it.
        • Polarbear
          • Feb 2012
          • 1070
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          +1
          Dev can only end up on the page if there is no bias on the mag.
          Press the GREEN button!!
          • irokkas
            • Oct 2012
            • 18
            Solved
            Thank you all for your replies.It was the quenching lamp above the drum.
