af 2022
  • Gab
    • Aug 2015
    • 671
    af 2022
    paper jam when paper just exits(It exits about 1cmm and stop). Also some times double feed occurs. It happens when using both paper cassetes. The green gear that we define which size of paper is in use is ok. I suspect main motor.
    Any idea?
  • Polarbear
    • Feb 2012
    • 1070
    Re: af 2022
    Any idea?
    Double feed from both trays? What's the condition of the friction pads in these?
    Is there any visible damage to the paper when misfeed occurs?
    Sent from my SM-G950F using Tapatalk
    Press the GREEN button!!
    • eccelobo
      • 113
      Re: af 2022
      Any idea?
      For double feed, check the separation pads. For fuser jam, check pressure roller.
      Enviado desde mi SM-G920V mediante Tapatalk
        Re: af 2022
        Any idea?
        what's the jam code?
        what have you tried?
          • 37459
          Re: af 2022
          Often a jam just as the paper starts to exit trail edge jam from incorrect paper size. Check the jam code in SP mode. Do not use the the SCM log data print out as it does not show the paper size code. Just because the paper size dial is in the correct position does not mean that the size switch is functioning correctly.
          • Gab
            • Aug 2015
            • 671
            Re: af 2022
            Peper stops just as paper exits . I know that usually this happens when wrong paper is at paper cassete.
            It doesn't happens here.
            I have noticed that this kind of paper jam happens also when there is a main motor mulfunction.
              • 37459
              Re: af 2022
              Once again what is the jam code?
              • Iowatech
                Not a service manager
                • 3930
                Re: af 2022
                If the main motor stops there is an error code displayed.
                • bob marley
                  • Jan 2012
                  • 1339
                  Re: af 2022
                  check paper exit sensor
                  Live for yourself and you will live in vain. Live for others, and you will live again
                    • 37459
                    Re: af 2022
                    If he would only tell us what the jam code is.
                    • fshead
                      • 2376
                      Re: af 2022
                      Is the registration on jammed copy on ponit?
                      I never had a motor fail on any of these series.
                      The fuser units need to be clean,entry guide plate,fingers,cl roller and
                      as stated b4 check the pressure roller for flat spots.
                      Did you try running a copy via bypass
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: af 2022
                        multi feed is due to a worn friction path OR the tray bottom plate pressure that is to heavy ...
                        Jams in exit without creases is moisture paper (condens on sensor) OR wrong paper size setting OR ...
                        Never i have replaced a main motor!
                        • StephenB
                          • Aug 2015
                          • 240
                          Re: af 2022
                          I have never had a main motor failure, many of these out there.
                          Stick to the basics, Pick up tire, sep pads, clean reg sensor, check the paper tray sensors on the back of machine frame ( easy to miss an out of position sensor)
                          • Wild Bill
                            • Jul 2005
                            • 774
                            Re: af 2022
                            Remember...KISS
                            Very Important Acronym for nubs.
                            Izzy
                            • DRichard
                              • May 2008
                              • 482
                              Re: af 2022
                              Originally posted by Wild Bill
                              Remember...KISS
                              So true...
                              "Enjoy every sandwich."
                              -- Warren Zevon
