light copies
  • Gab
    • Aug 2015
    • 677
    light copies
    Copies (and printings ) from MP 2501 are light. Drum and developer are new (about 2k copies) . |Is there any way to
    make them darker?
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: light copies
    First try converting the black colour to cyan color.
    Is this also to light? Then it is not the black PCDU...
    Check this out.
    • Elmo
      • Feb 2010
      • 541
      Re: light copies
      Did you clean the laser glass
      are you using original drums or compatible
      I Used To Live To Fix Things Now i Fix Things To Live
      • davel
        • Oct 2011
        • 1108
        Re: light copies
        Check this out.
        It is black and white machine how does he make it print colour
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: light copies
          Never underestimate a European!
          • Mark Bbb
            • Jun 2012
            • 1662
            Re: light copies
            What is the total counter?
            Is the grounding plate in contact with the paper transfer roller discharge?
            • StephenB
              • Aug 2015
              • 246
              Re: light copies
              I had the same problem, had to use an OEM drum. Compatible will not give good density for whatever reason.
              Saw a previous thread advising to also use Type 28 developer on these.
                Re: light copies
                make them darker?
                is it OEM Toner and drum?
                there are adjustment procedures to darken in the manual... but I would CLEAN the machine before making ANY adjustments
                • Gab
                  • Aug 2015
                  • 677
                  Re: light copies
                  Toner , drum and developer OEM. I eecuted forced toner and image was the same. I believe it's the voltage that attracts toner to paper . Can anybody remind to me which is this voltage.
                    • 37628
                    Re: light copies
                    The term OEM is absolutely no way to be guaranteed of quality. If it is not Genuine Ricoh, it is not guaranteed by Ricoh to perform correctly in Ricoh machines.
                    Doing a forced toning does not guarantee that toner is added. If Vt does not change, fresh toner is not entering the developer. A common problem with OEM toner is bottle length being too short. Confirm that the bottle is actually turning. Check that nothing is obstructing the toner path from the bottle to the development unit.
                    • fshead
                      • 2378
                      Re: light copies
                      you can always manually spike the dev unit with toner,make a funnel and pour 1 tsp in the opening and then run a few blank sheets .
                      AFTER 10 sheets you should see the toner has made it to the mag roller..
                      i ve played with the bias and charge on these b/w units but i stopped selling them...my lungs thank me
                      • fshead
                        • 2378
                        Re: light copies
                        also check the contacts on the transfer roller clean and bend if needed
                          • 37628
                          Re: light copies
                          I have had machines with the passage in the pcu clogged with toner to where the toner will not pour through.
