Sc 552 after fuser belt replacements!
  • ShonRipz
    • May 2017
    • 33
    Happened to me last Friday on a mpc 4502 and again this morning on a mpc 2003. Followed procedure for fusing belt replacement and when powering on always has a sc552 code regardless of what I do. Currently awaiting call from tech support. Anyone had these issues? Really bad when you have to leave a customer down after returning with parts. :/
  • fshead
    • 2376
    Re: Sc 552 after fuser belt replacements!
    DID you change just a belt or complete fuser belt unit?????
    Was there a code before changing belt?
    • Elmo
      • Feb 2010
      • 541
      Check that the thermistor wirse are correctly placed and not covering the cutout in the frame to allow thermopile access to the belt
      I Used To Live To Fix Things Now i Fix Things To Live
      • Wild Bill
        • Jul 2005
        • 774
        Did you install the reset fuse?
        Izzy
        • mikadonovan
          • May 2008
          • 2931
          There is a fuse and a special reset procedure for this. Replace the fuse in the fuser unit and execute sp5810-002, then reboot machine.
          NEVER ASSUME ANYTHING
            did you replace JUST the belt or do a full rebuild on it....?
            reset any of the items needed in SM?
            what was the reason for the replacement? any codes before replacement?
            so many questions you didn't cover.
