Ricoh MP4002
  • vickter200
    • Mar 2018
    • 18
    Ricoh MP4002
    Hi everyone, so here's my first post. I've been an independent Ricoh tech for 2 years but have been in the industry for 12 years. Im glad to have joined and i get a lot of great tips from here.
    I have a Ricoh MP4002 that automatically wants to format the HDD as if i just replaced it. and its driving me crazy as i have never seen this happen. So far I've replaced the following,
    1. HDD and updated Firmware
    2. Satie PCB with Cables and another HDD
    3. today i swapped the controller with a parts MP4002 including the NVram.
    Any Idea whats causing this?
    Vic
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh MP4002
    Off the top of my head.
    Maybe a incompatible HDD.
    The genuine part was a Western Digital 160Gb, so I wouldn't use anything larger than 500Gb.
    Maybe a security feature like DOS or HDD encryption is enabled.
      • 37556
      Re: Ricoh MP4002
      Possibly an incompatible drive partitioning, MBR or low level format. Maybe testing the drive with a utility such as SpinRite or Minitool Partition Wizard.
      Home of Gibson Research Corporation
      MiniTool Partition Wizard | Best partition magic alternative for Windows PC and Server
      Partition Wizard can also be used to resize USB drives when you need something smaller for firmware.
      • DRichard
        • May 2008
        • 482
        Re: Ricoh MP4002
        Vic
        My first guess is a partitioning problem. Due to a contract with a national security lab, we routinely replace HDDs in these models. We buy generic, 160GB drives and set them up using an external HDD docking station. I recommend pulling your drive and reconfiguring it on a PC. In Disk Management, you need to set the HDD up as a new simple volume. Do not assign a drive letter. Select your settings, (NTFS, new volume) and do a quick format. When finished, you should see it described as "Healthy (Primary Partition)". You can then reinstall it. I always reformat it once it is back in the copier. Good luck.
        "Enjoy every sandwich."
        -- Warren Zevon
        • vickter200
          • Mar 2018
          • 18
          Re: Ricoh MP4002
          Thanks for the reply, I've already checked these settings ad non point to this symtom. It was was my first thought. Thanks Again!
          • vickter200
            • Mar 2018
            • 18
            Re: Ricoh MP4002
            Thanks for the reply, I've never have used this procedure, but try it. Keep in mind I've tried three new HDD's all generic under 500gb. i use the same procedure on other copiers with no issue like this one.
            I'll keep you all posted on the remedy once i figure it out.
            Thanks again.
