Service Call sc400 on a SP C250 printer
  • wackywiz
    • Aug 2025
    [Error Code] Service Call sc400 on a SP C250 printer
    I have a printer that just started popping this error. I see other people with similar models have the same issue & have cleaned out 3 sensors & it has fixed the problem.
    I am looking for information on where the sensors are on this particular model. I assume they are somewhere towards the back of the printer but I have pretty much ripped this thing apart & am still stymied.
    Any help will be greatly appreciated as this thing weighs a ton & I don't relish having to remove it for shop service.
    Re: Service Call sc400 on a SP C250 printer
    your service manual will have the location of all flag and optic sensors
      • 37628
      I just downloaded the service manual and confirmed this. It is called the ID Chip Board. Clean the lenses of the sensors with a soft cloth slightly moistened with water only. If there is evidence of toner scattering, you will need to correct that or the SC 400 will return.
      • 8T2
        • Aug 2015
        • 257
        Agreed, if any PCDU's are blowing toner they need to be replaced, could also be a worn image transfer belt.
        Sent from my ALE-L02 using Tapatalk
