C2503 w/ Wireless Option - No Printing
  • Stormhammer
    • 150
    Here's on odd one by me. Recently, I had a customer change their network infrastructure which I know is the root cause of this issue, but I have yet to glean a solution out of it. This C2503 will connect to the wireless network properly and the signal strength is good as expected since it's right across from the wireless router. Scans happily pass through the machine to people's emails without issue as well. However, when any printing is done it passes through the print queue on all their workstations and then the machine does nothing. Nothing gets passed to the machine. I have ensured that the MFP is properly configured on every workstation and have tried three different driver types and still nothing. One would think that if, for instance, the wireless router was a different 802.11 standard such as AC which is outside the wireless option's capabilities that it would receive no signal and none of the workstations would be even able to detect anything was there when you configured the workstation to use a printer on that TCP/IP port. Occam's Razor tells me I'm missing something, but I just don't understand what.
  • Kimi
    • Feb 2018
    • 105
    Re: C2503 w/ Wireless Option - No Printing
    Does the print job hit the machine at all?
    • Elmo
      • Feb 2010
      • 541
      Can you ping the ip address of the copier from any of the workstations
      I Used To Live To Fix Things Now i Fix Things To Live
        • 30158
        recheck copier and workstation ip address and ping the printer
        • Stormhammer
          • 150
          To answer the questions that have been asked.
          I can ping the printer from all the workstations.
          The job passes through the queue on all the workstations but never appears at all on the machine.
            • 37473
            This sounds like a fire wall problem. Was part of the network infrastructure change adding a network security package such as McAfee? I have seen this with McAfee immediately after after installing their software fire wall. The first time a print job is sent the firewall will will pop up a message asking whether or not to allow it. If the the user fails to read the message before clicking to block, they block all IP printing from that workstation. This will also happen if there is no one at the workstation to see the firewall message and it times out and blocks. An example is a server.
            Do all the workstations print directly to the C2503 or do they print through a server or are shared print queue?
            • Stormhammer
              • 150
              They are configured to print directly to the MFP.
                • 37473
                Then check the firewall on all of them.
                • StephenB
                  • Aug 2015
                  • 243
                  Check for a network conflict, another device with the same IP. Disconnect or turn the System off, and then ping the IP. If you get a response, there is another device on the same IP.
                  • Cipher
                    It's not easy being green
                    • May 2006
                    • 1309
                    You can get a ping response and the scan to email is working.
                    So that indicates that there is wireless connectivity via the router.
                    I assume that you can also get to the Web Image Monitor from a PC?
                    • Is DIPRINT enabled?
                    • Are there any printer errors being logged in the Classic Printer mode?
                    • Has print job authentication been enabled?
                    • Has the access range control been enabled?
                    • Is there a firewall enabled on the wireless router? (may need to create a inbound TCP port 9100 forwarding rule).
                      • 30158
                      change the ipaddress on the printer and try printing from the new port
                      also try changing from raw 9100 to lpr port using print queue that may tell you 9100 may be blocked
                      • Stormhammer
                        • 150
                        Web Image Monitor is accessible from the IP that the MFP was given. I believe this to be a firewall conflict of some regard and will test this come Monday. Results are forthcoming since the customer doesn't seem to have IT.
                        • drew007
                          • May 2018
                          • 21
                          Is there a solution like papercut involved ? prints would go through that for tracking/accounting. That server would need to see the new IP address also.
                          • FrohnB
                            • Jul 2017
                            • 1919
                            Go into user tools and "Restore IEEE defaults". Had a customer that moved from one building to another, running on a wireless network, and I spent a couple afternoons there doing everything I could think of, and finally another tech told me over the phone to hit that "restore" in user tools "just to see what happens", and WOOFTA, Machine functioned normally after that.
                            Omertà
                            • Stormhammer
                              • 150
                              I bet this is it. Dollars to donuts they have the same security software running on all workstations with an identical profile. It's been difficult to extract anything useful since they have no idea. They don't even have an IT dept. The cable company set up all their equipment and they just sort of go along with whatever they say.
