scan to email using yahoo.
  • aviso66
    • Dec 2012
    • 201
    Hi, Has anybody still using yahoo for ricoh scan to email recently?
    Bec i have tried to setup and it's not working. I try to set the smtp.mail.yahoo.com and try the connection test and it's not successful. Is there any certificate for yahoo to import into the machine?
    Please assist.
    thanks
  • sandmanmac
    • 3951
    Re: scan to email using yahoo.
    Please assist.
    thanks
    Yes, and why do you NOT THINK that the model number is important to mention in your post?
    Because you're most likely trying to connect an older machine that doesn't support encryption.
    And also....why would you think that you're the first person to ever have difficulty setting up scan to email?
    Search the forum....there are hundreds of threads
      • 35267
      Try the following settings. Connection test will fail if the port is not correct.
      Outgoing Mail (SMTP) Server
      • Server - smtp.mail.yahoo.com
      • Port - 465 or 587
      • Requires SSL - Yes
      • Requires TLS - Yes (if available)
      • Requires authentication - Yes
      Your login info
      • Email address - Your full email address (name@domain.com.)
      • Password - Your account's password.
      Attached is a Ricoh Knowledgebase document on installing a certificate for SMTP over SSL. Before downloading a certificate, check to see of it has expired.
      How do I setup SMTP over SSL on a Ricoh Family group device.pdf
      • aviso66
        • Dec 2012
        • 201
        • Port - 465 or 587
        Your login info
        [ATTACH]39605[/ATTACH]
        Tested using afmpc2050.
        but not working when i set smtp.mail.yahoo.com with port 465 or 587 as I test the connection it failed. but if i use IP 98.136.96.80. connections is successful. However, tested the scanning but still failed.
          • 35267
          Check the DNS setting. Try setting one of the DNS servers to the Google public DNS 8.8.8.8
          • aviso66
            • Dec 2012
            • 201
            smtpc connection closed err 101
            by the way: firefox version 60.0 I have check the cert that there's no google internet authority in the equifax list..
            • sandmanmac
              • 3951
              As I told you last week, you're not the first with this issue.
              I wasn't even the first person 5 or 6 years ago when I faced this problem for the first time!
              There are dozens of threads that provide you with non-encrypted workarounds. Look around!
                • 35267
                You now have the name of the certificate to use. Do you lack the capability to search for it, or are you just to lazy to do so?
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Mpc2050 2550 series doesn't have SSL you can use mpc2051 and newer machine must have ssl
                  Regards Mark
                    • 35267
                    If you read the the list of applicable models at the end of the knowledge base document that I attached to my first post in this thread you will see that the MP C2050/2550 are models that document applies to.
                    • quocve
                      • May 2012
                      • 20
                      You have to set up network connection smoothly on the device, then later make settings for scan to email as slimslob instructions.
                      "smtpc connection closed err 101" is the result of incomplete network connection setup.
