MPC6501 print from USB
  • black
    • Aug 2015
    • 6
    [Misc] MPC6501 print from USB
    Good evening.
    I wish to add the "usb stick print" feature to a ricoh mp c6501.
    With or without hub adapter i'm able to scan to usb drive.
    But when i try to print, the window doesn't show up and in "print sp" there is no sp to add the feature!
    I really need this, even with a custom firmware if necessary (if available!).
    Anyone can help me, please?
    Thanks in advance.
  • mikadonovan
    • May 2008
    • 2931
    Re: MPC6501 print from USB
    This model introduced the "scan to usb" option. I believe you will need to update to a newer model for the "print from usb" capability.
    NEVER ASSUME ANYTHING
      • 37538
      SP5985-002 enables the USB port(s) on the controller.
      From the installation instructions for the USB2.0/SD Slot Type D (D505-01) Scanner SP 1013 to enable scanning.
      Use a USB extension cable to bring the connection up to the panel and fancy it up to your desire. It will allow print and scan to USB thumb drives and with an adapter SD cards.
      Or you could order and install the USB2.0/SD Slot Type D (D505-01).
