ricoh mp2852
  • tullio
    • Feb 2012
    • 268
    ricoh mp2852
    IMG-20180514-WA0007.jpg problem of disconnection, ricoh mp2852 - print,copy is ok -can not access web browser
  • tullio
    • Feb 2012
    • 268
    Re: ricoh mp2852
    ricoh mp c 2051 is ok -
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: ricoh mp2852
      you are having a connectivity problem.
      IP address of the Gateway is wrong.
      • tullio
        • Feb 2012
        • 268
        Re: ricoh mp2852
        I tried with a mpc2051 and ricoh mp2851 the connectivity is ok. with the same address.
        • tullio
          • Feb 2012
          • 268
          Re: ricoh mp2852
          • tullio
            • Feb 2012
            • 268
            Re: ricoh mp2852
            • tullio
              • Feb 2012
              • 268
              Re: ricoh mp2852
              • Polarbear
                • Feb 2012
                • 1070
                Re: ricoh mp2852
                Have you checked that there are no access control settings that are blocking your IP on the device?
                Recheck all settings, including subnet mask and gateway also.
                Press the GREEN button!!
                • tullio
                  • Feb 2012
                  • 268
                  Re: ricoh mp2852
                  where is it?
                  I checked everything. same problem. i sorry....
                  • sandmanmac
                    • 3981
                    Re: ricoh mp2852
                    where is it?
                    Is there an echo in here? echo in here?
                      • 37487
                      Re: ricoh mp2852
                      Sounds like he doesn't know how to properly use Reply With Quote.
                        Re: ricoh mp2852
                        doesn't sound like he is a tech!
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Re: ricoh mp2852
                          when you ping the IP address of the mp2852, does it repply from that ip address?
                          If no, then that is your problem.
                          • sandmanmac
                            • 3981
                            Re: ricoh mp2852
                            As he stated in his very brief initial post, he can print to it, so it's just a guess that he can ping it.
                            My money's on the access range setting, or web setting disabled
                              • 37487
                              Re: ricoh mp2852
                              Check the setting of SP 5985-001. It should be set to 1. If it is set to 2 WIM might be disabled.
                              Do the following memory clears:
                              • SP5801-010 Web Services
                              • SP5801-011 NCS You will have reenter all network settings
                              • SP5801-020 Web application settings.
