Ricoh MP C5501
  • Reed
    • Feb 2011
    • 241
    Ricoh MP C5501
    I recently rebuilt the fusing unit on this machine and now it keeps double imaging/smearing . Especially near the edges (copying/printing portrait). The customer is using 28 lb bond paper so I bumped up the temperature settings, but the machine is still doing the same thing. I have looked at the fuser and everything appears to be in place. Any help would be appreciated. Thanks in advance
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh MP C5501
    Forget to put some Springs back on? If I remember correctly, you have to turn (loosen) the pressure levers and remove the pins holding the springs while disassembling Or maybe the pressure roller bearings aren't seated properly and therefore not letting the press roller fully press against hot roller/ belt.
    Omertà
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Re: Ricoh MP C5501
      Check that you have used the right bearings especially for the Pressure Roller. If you used the mini parts maintenance guide from the Product Support Guide it lists the wrong bearing (AE030074) for the Pressure Roller. The correct part is AE030081 - slightly larger outside diameter I believe.
      • Reed
        • Feb 2011
        • 241
        Re: Ricoh MP C5501
        Ended up replacing the entire heat roller. That took care of the problem. I had previously just replaced the sleeve...memo.. just don't be cheap
        • Tatteous
          • May 2017
          • 24
          Re: Ricoh MP C5501
          This model requires thick1 or middle thick to fuse properly using 28# paper.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Re: Ricoh MP C5501
            You can also buy the printer version for this machine and mod it to fit...way cheaper than the original.
