Boot sd card
  • Ehab
    • May 2018
    • 4
    Boot sd card
    Does anyone have information on this utility?
    I have read that when the boot program Flash ROM is damaged or corrupted, the SD card can be used to start the machine and download the firmware to restart the program. There is a special utility to format the sd card to boot from it.
    • 37658
    Re: Boot sd card
    The are issued to regional reps if and only if they are sent to assist with a repair where Ricoh has already determined that it will be needed. You will need to arrange a support visit from your Ricoh support rep.
    In the days of firmware updates with the PCMCIA cards, there was a dip switch that could be used to force booting from the PCMCIA card. Occasionally needed to be used if power failed during an update.
    • sandmanmac
      • 3991
      Re: Boot sd card
      Are you sure that's the issue with the machine?
      What model? Describe the problem you have. What led to the condition?
      • Ehab
        • May 2018
        • 4
        Re: Boot sd card
        Copier model mp4000. The error code sc819 or sc878
        • fshead
          • 2378
          Re: Boot sd card
          EITHER??
          That narrows it down...
            • 37658
            Re: Boot sd card
            MP 4000 or MP 4000B? If it is a B and you tried to add Printer/Scanner function by just adding a Printer/Scanner SD Card, you screwed up. To add printer/scanner requires more than just an SD card. Read your service manual.
            SC 819 Fatal kernel error - no memory with SP5-985 turned ON, install memory turn SP5-985 to off and remove memory
            SC 819 Fatal Kernel error - update fw WebUapl 1.10 Network DocBox 1.07M Web Support 1.53
            SC 819 Fatal Kernel error - with '7061 6765 6f75 743a 20' appearing after code, add 256Mb Memory
            SC 819 Fatal Kernel error - turn off NIB SP 5-985-1 to 0 if a 'B' model with no scanner or printer option
            SC 819 Fatal Kernel error when HDD removed - Turn off on-board NIC SP 5985-1 to a 0
            SC 819 Fatal Kernel error - replace controller
            SC 819 Fatal kernel error - set machine type with Plug & Play use SP5-907
            SC 819 Fatal Kernel error - with Java+PScript installed you need 512K memory
            SC 819 Fatal kernel error - replace PostScript SD card
            SC 819 Fatal kernel error - replace HDD
            SC 819 Fatal Kernel error - update system fw to 1.14 or higher
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Re: Boot sd card
              most likely bad hard drive.
              Mystic Crystal Revelations
              • quocve
                • May 2012
                • 20
                Re: Boot sd card
                This case I think is due to a corrupt Dram, or HDD. Check them out and replace them.
