7503 dead
  • mikadonovan
    • May 2008
    • 2931
    7503 dead
    Hi, All. I have a 7503 that does absolutely nothing when the power button is pressed. I have verified power to the AC drive board, and both fuses test good. Before I start board swapping I thought I would see if anyone has ran into this issue before.
    NEVER ASSUME ANYTHING
  • Wild Bill
    • Jul 2005
    • 774
    Re: 7503 dead
    Any DC Volts? I would definitely suspect the PSPWB
    Izzy
    • mikadonovan
      • May 2008
      • 2931
      Re: 7503 dead
      I found the problem. The hard key was sitting cockeyed in it's mount and not even hitting the microswitch.Hard key.jpg
      I noticed the 9003 I have has a wonky switch, too. Something to keep an eye on, I suppose.
      • Gab
        • Aug 2015
        • 671
        Re: 7503 dead
        If it not power supply before i replace board i check for groundings.
        • sandmanmac
          • 3981
          Re: 7503 dead
          C'mon man...he provided the solution immediately above your post, and this is about the 3rd time today you've provided solutions to threads that are already resolved.
          Read the thread!
            • 37484
            Re: 7503 dead
            Read the thread!
            Damn Sandy, I thought I was the only one who was getting to be a grumpy old man.
            • sandmanmac
              • 3981
              Re: 7503 dead
              Not at all Tim, I bit my tongue on the first 2 that I read, and I just couldn't do it again
              Dude doesn't read anything but the initial post.
                • 37484
                Re: 7503 dead
                I've seen a few lately that I don't even think read that much.
