MP3351 sc642
  • quocve
    • May 2012
    • 20
    MP3351 sc642
    Hi all !
    MP3351 error message sc642, I removed the option which still does not solve the problem. Do you have any way to solve this problem without replacing the controller board?
    Please help me. Thank you all!
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    Re: MP3351 sc642
    its either of BICU or Controller Board is defective.
    fix the customer first then fix the machine... its simple and makes life more easy.
    • sandmanmac
      • 3990
      Re: MP3351 sc642
      You sure about that SC? I have no reference to it on that model
      • nokktekk
        • Mar 2018
        • 44
        Re: MP3351 sc642
        Please remove the controller board and reseat all the connections on the boards. If there is a hard drive format it and run scan disk. Also make sure that ALL FIRMWARE is up to date.
        • nokktekk
          • Mar 2018
          • 44
          Re: MP3351 sc642
          By the way, are you sure its Sc642? Maybe you meant 672.
          • sandmanmac
            • 3990
            Re: MP3351 sc642
            If it's not too much to ask, consider reading the post immediately above yours!
            ..also FYI, he PM'd me due to some strange account limitations that won't allow him to respond here saying that it IS the right code, and he's aware that there is no documentation about it, which is the frustrating part, but if I understand correctly he tried the controller in another machine and got the same result, so it seems like imaginemoko deserves some props!
              • 37628
              Re: MP3351 sc642
              What option did you remove?
                • 37628
                Re: MP3351 sc642
                From TSRC Service look up(general, not specific to MP 3351)
                SC642 Communication timeout error between controller and operation panel
                Check the connection path. Controller to IPU and IPU to operation panel. Look for damaged cables or bent or broken pin(s) in the connector on the board. Might also be a cold solder joint.
                • quocve
                  • May 2012
                  • 20
                  Re: MP3351 sc642
                  I will try to find the cause and will tell you the results.
