help me ! ricoh mp 5000 sc 440
  • mucinhanoi365.com
    • Oct 2017
    • 4
    [Error Code] help me ! ricoh mp 5000 sc 440
    Re: help me ! ricoh mp 5000 sc 440
    RTFM!
    • francisco
      • Nov 2009
      • 168
      paper with hy humity,change it
      • sandmanmac
        • 3990
        WOW! You ought to consider RTFM too
          • 37641
          I think he is trying to say he does not have The Fing Manual in order to Read.
          • sandmanmac
            • 3990
            I'm sure that's the case, but he's obviously got the internet, so he's got Fing Google , and could easily get one. It took me one try, and it was the first thing listed.
              oh hell Fing no! wait until you can post on CTN.... don't TRY to finger out anything.... just rely on others to do your homework for you!
              no not grumpy... just really really tired of lazy ass people.
              • mikadonovan
                • May 2008
                • 2931
                Better take a look at the ITB.
                NEVER ASSUME ANYTHING
                • LNorris
                  • Sep 2008
                  • 645
                  guys, i understand the RTFM, but i had this same issue a few years ago. changed every f'ing board on it.
                  it was the humidity in the paper. machine sat right under ac vent. brand new machine. it is a thought tho
                  • mucinhanoi365.com
                    • Oct 2017
                    • 4
                    I changed paper but it was an error
                    • sandmanmac
                      • 3990
                      Haha....apparently he is too. He gave you props!
                      Then it has to be the whatchamacallit
                        • 37641
                        If it is too much moisture in the paper, you need to try fresh paper that is either it its original moisture resistant wrapper or has been store in a dry moisture proof container. If dry paper corrects the error I would recommend installing tray heaters.
                        Got the location of the source of the code.
                        Mika is on the right track.
                        It might be a good idea to download Goose's guide and use it when trouble shooting older models.GG April 2013.zip
                        One question, what was the last thing that was done to the 5000 before the error came up?
                        • bob marley
                          • Jan 2012
                          • 1339
                          that is right Sc 440 is Transfer belt bias error
                          Live for yourself and you will live in vain. Live for others, and you will live again
                          • imaginemoko
                            unTrusted Tech
                            • Jan 2008
                            • 289
                            if it happens you rebuild your transfer unit and you interchange the red and white connector with the T and F marks. it could one of possibilities.
                            fix the customer first then fix the machine... its simple and makes life more easy.
                            • vargue
                              • Oct 2011
                              • 404
                              paper is moisturized i have customer water spilled in duplex and after change paper do sc440 .if yo have hot air conditioner .exposed to side machine for 2minuts.
