Ricoh 201 firmware update help
  • afterhours
    • Mar 2017
    • 152
    Hello everyone,
    I am a Konica Minolta tech but am doing a friend a personal favor. I need to know how to properly update firmware on a Ricoh 201. I dont know if I have the wrong manual or firmware but i keep getting a file extension error. Please, any help would be greatly apreciated.
    Thank you
    Im a Loser Baby!!!
  • mikedci
    • Jul 2010
    • 227
    Re: Ricoh 201 firmware update help
    remote firmware will be a .rfu
    sd card firmware will be .fwu
    • DRichard
      • May 2008
      • 482
      Originally posted by afterhours
      Hello everyone,
      Thank you
      Make sure your firmware file-type matches the the method you are using to update it. For instance...SD card uses one type, and uploading through your network connection uses a different type. SOP is different. Naming your file folder correctly is important. You know what? Get a manual...it will tell you all you need to know. It is easy to update firmware, but proper procedure is important. Good Luck!
      "Enjoy every sandwich."
      -- Warren Zevon
        • 37488
        Normally firmware is downloaded as part of a .zip file. The .fwu or .rfu files need to be extracted to the proper location for installation.
