Problem in ricoh c232
  • hosam88888
    • Jul 2025
    Problem in ricoh sp c232sf
    A replace print cartridge message appears
    The printer counter allows you to print a certain number of copies and then exits this message even though there is ink in the printer
    Do you have a solution to this problem or is there a program where you can stop the printer counter?
  • Iowatech
    Not a service manager
    • 3930
    Re: Problem in ricoh c232
    Is that machine using OEM (supplies bought from Ricoh) or aftermarket (supplies bought from any other source)? Please be honest as it makes a big difference.
    • sandmanmac
      • 3981
      What do you mean "even though there is ink in the printer"?
      What are the toner levels? provide a supplies status page - and don't just tell us that 'there should be toner because they're not that old' or something foolish.
      Frankly, it's a crappy little unit, and when the chip detects the cartridges has run the expected amount of pages, you have no choice but to replace the ridiculously expensive AIO cartridge. Period.
      • hosam88888
        Is there a solution to restore the chip To work again Without the need for replacement
        • hosam88888
          This printer It's not new I've bought a used And all that appears message (replacing the Cartridge) I change the chip and then work again, but is there a way for the chip to work again without replacing it
          • Lagonda
            • Aug 2008
            • 1649
            No, they are a one shot job, once expired you have to pay your money to get new ones.
