aficio mp4001 sc220 power source
  • MIGUELMARCHENA
    • Feb 2018
    • 192
    good day
    I have sc220 in a machine, testing this and that check that it is the source. I have reviewed it completely changing parts etc but still giving the sc220.
    Any type or spare that have changed from the source that has served and solved?
    Thank you very much for your answers
    • 37484
    Re: aficio mp4001 sc220 power source
    Where did you get the idea that SC220 has to do with the power source? SC220 is a laser sync error and has nothing to do with the power. Did you even look in the service manual or do you not have one?
    SC 220 Laser sync detect LD0 error - check LD unit for toner dust blocking detector
    SC 220 Laser sync detect LD0 error - replace IPU
    SC 220 Laser sync detect LD0 error - replace sync detector board
    SC 220 Laser sync detect LD0 error - replace LD unit assy.
    • MIGUELMARCHENA
      • Feb 2018
      • 192
      SC 220
      SC 220
      SC 220
      SC 220
      [/CITAR]
      Hello thanks for answering changed everything Full laser, LD wiring etc part by part and nothing was given to change source and ..ok full works super well, more than two months without any problem and with the original laser of the machine.Choose to try again with the original power source and other times sc 220I reinstall the borrowed power source and ok full and I tried it with another machine to which I had changed everything with the same code sc 220, when changing the source for one of a machine ok and full, it works ...weird, no?
