How do i check if a SOP unit is complete?
  • fshead
    • 2376
    hi
    I just started to see lease return mpc401 and mpc3003 units with SOP
    panels.
    As these are returns the customer at times pulls hard drives and anything they think might be a
    security issue.
    Is the NFC reader built in or sits on panel? iS IT needed to print/scan from phones?
    How do I check that units I buy can connect to android phones?
    THANKS
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: How do i check if a SOP unit is complete?
    Originally posted by fshead
    hi
    panels.
    security issue.
    THANKS
    I do not believe there is an NFC reader in the panel. They come with blank NFC tags that can be programmed using a smartphone so that phones with NFC readers can scan the tag and get the connection info for use in the Smart Device Connector app.
    If there was one it would likely be soldered onto the main board like the Bluetooth module is. The WIFI is a small separate board of it's own but I doubt anyone would remove that when it can be disabled.
    • fshead
      • 2376
      thanks
      i saw on two of them some tape residue on the lower outer border of the control
      panel and it made me wonder my question.Plus i saw a youtube video where they
      had a sd card size NFC"card"..
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        It's just a tag you stick on the machine when you set it up.
        Mystic Crystal Revelations
        • fshead
          • 2376
          thanks
          like the poscript 3 sticker,meaning it has no importance?
          other than saying it is there
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            thanks
            Exactly. You could just as easily buy a generic NFC tag to use in the same way.
              • 37513
              thanks
              Primarily used as a visual indicator of where to place the mobile device.
              • fshead
                • 2376
                I remember when all I had to do was to rebuild the drum,fuser unit or paper feed...
