SP 4520DN drops off network
  • MFPTech
    • 486
    [Misc] SP 4520DN drops off network
    brand-new SP 4520DN drops off the network.
    The printer goes to energy save mode and does not wake up when sending a print job to it.
    The only way to print is by turning the machine off and on.
    Checked the default network settings
    Sleep Mode Timer is 60 minutes
    Ethernet Speed:Auto Select: Disable 1Gbps
    Any ideas please?
    Thanks!
    • 37532
    Re: SP 4520DN drops off network
    Is wake on LAN enabled? Does the network actually support wake on LAN?
    • Mark Bbb
      • Jun 2012
      • 1662
      Yes, and check the operation with "powercfg /lastwake"
      And look for activity at your "
      Wake-on-LAN-event", it should be mentioned in the "System event log".
      • Tecnicopia
        • Jun 2015
        • 31
        Can be a network issue...
        Test It with a rj45 Direct to a laptop, try It with IP adress un port.
        Check the driver, if It is a WSD, install the driver from Ricoh.
        Enviado desde mi Redmi 4X mediante Tapatalk
