Ricoh mpc 4501
  • vicalvarez
    • Mar 2014
    • 33
    [Error Code] Ricoh mpc 4501
    Hey I change k developer and the machine give me this code sc 364 any ideas
    Sent from my SM-J105B using Tapatalk
  • Tecnicopia
    • Jun 2015
    • 31
    Re: Ricoh mpc 4501
    Have that code in mind...
    The development unit don't turn, or It does but very hard.
    Check that first, dissamble it and rotate manually.
    Compare it with another unit.
    Enviado desde mi Redmi 4X mediante Tapatalk
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: Ricoh mpc 4501
      Did you use genuine developer?
      Hit it.
        • 37533
        Re: Ricoh mpc 4501
        Did you reassemble the PCDU properly. If the error was immediate upon turning on after changer the developer, you forgot to properly reconnect the harness from the drum unit to the development unit.
        • Gab
          • Aug 2015
          • 671
          Re: Ricoh mpc 4501
          have you executed the right program after dev replacement.
          Have you make any copy before running the program?
          • vicalvarez
            • Mar 2014
            • 33
            Re: Ricoh mpc 4501
            O fixem esa the d.i. Sensor
            Enviado desde mi iPhone utilizando Tapatalk
