RICOH AFICIO MP SC 672
  • mido
    • Nov 2011
    • 177
    Hi,
    I have Ricoh MP 3350, shows SC 672, and I cann't enter the service mode to clear the memory.
    can anybody tell me how to solve this problem?
    Regards
    Imad
  • francisco
    • Nov 2009
    • 168
    Re: RICOH AFICIO MP SC 672
    Originally posted by mido
    Hi,
    Regards
    Imad
    try turn on without HDD, if sc 672 appear , controler is dead.
    • drew007
      • May 2018
      • 21
      I've just changed the main control board on an mpc5503 due to intermittent sc672 errors.
      waiting to see how it goes.
      • fshead
        • 2378
        not looking to hijack tread but is sc 672-12 the same for a mpc401sr regarding possible bad harddrive?
        i saw the rtb 56 regarding FW
        • Polarbear
          • Feb 2012
          • 1070
          Hi.
          The only reference to SC672 is in the MPC300/400 manual:
          672 CTL
          D
          Controller-to-operation panel communication error at startup
          After powering on the machine, the communication circuit between the
          controller and the operation panel is not opened, or communication with
          controller is interrupted after a normal startup.
          ! Controller stall
          ! Controller board installed incorrectly
          ! Controller board defective
          ! Operation panel connector loose or defective
          1. Check the harness connection.
          2. Replace the controller board.
          Press the GREEN button!!
          • CSI
            • Oct 2008
            • 73
            On an AFICIO MP 2352 I had to change the IPU card
            • fshead
              • 2378
              for me to think hard drive on my mpc401sr in my shop it acts like a bad hard drive where
              on my SOP panel after it loads the home screen if i hit copier or fax etc i get the please wait screen,
              and it never clears till it codes out.
              totally intermitent,and i just picked this up a few
              weeks ago so I have not spent a lot of time
              outside of doing FW update both package and romdata
              • davel
                • Oct 2011
                • 1108
                Do not try to clear memory, are you using the correct way to enter SP mode.
                • fshead
                  • 2378
                  thanks
                  i am not a memory clear guy,and yes i know how to enter the new service mode that is how i print out
                  FW ver in 5990-05..I am just too busy now to pull it apart and have 3 units I am needing to prep,test,calibrate,FW update etc..
                  I try to line up accounts i can pop them in b4 they
                  are ready..
                  • copyaction
                    • Oct 2007
                    • 991
                    On the 3350 remove the fax unit if it has it in addition to the Hdd.
                    • mido
                      • Nov 2011
                      • 177
                      I disconnect the controller and turn on the machine but nothing appears in the display. it's black
                      • francisco
                        • Nov 2009
                        • 168
                        disconnect the Hard disk ,not the controler!!
                        • mido
                          • Nov 2011
                          • 177
                          ok I disconnect the hard disk and power on machine. the screen shows these errors:
                          sc problems with hard disk
                          sc 860
                          sc 870
                          sc 872
                          sc 925
                          do u think problem is in hard disk drive?
                          • francisco
                            • Nov 2009
                            • 168
                            sc 860
                            sc 870
                            sc 872
                            sc 925
                            now format Hdd, and connect it again,if SC 672 apears again the problema is controller
                              • 37628
                              Or the HDD needs to be replaced.
