mpc3503 scanner noise
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    Anyone else have complaints about the chatter noise the scanner makes when it returns to home position? Clean and lube and it keeps coming back.
    I fix copiers ...Well Sorta
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3503 scanner noise
    no, i have no issues yet like these.
    Ball bearing?
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      No bearings, allways the rails, the noise comes to our machines after 3 - 31/2 years. As said, clean & lube - OK.
      Greetings...
      • LNorris
        • Sep 2008
        • 645
        there is a tech bulletin for the noise
        rfg067249.pdfrfg067249.pdf
        • guitar9199
          • Sep 2016
          • 1100
          Keep in mind there are TWO sets of rails... Upper and lower, both front and rear. I use a very light sewing machine oil, and just a tiny bit that I spread with my finger. Too much oil will attract more dust, and you're right back where you started.
            • 37653
            I like singer sewing machine oil. Doesn't become gummy. Doesn't dry out to become lacquer. A lot less expensive and more readily available than watch oil.
              i like TriFlow oil .. has Teflon particles in the oil.
              • Gab
                • Aug 2015
                • 677
                Have you tried vaselin/ A very small amount spred by finger .
                Also you can use grease
                  grease attracts dirt... not a smart move.
                  • Xcelsior
                    Ex-Tech
                    • Jan 2017
                    • 24
                    TriFlow is what they always gave Ricoh Techs, works perfectly for so many noises.
                    I would always put a few drops on a finger and just run it over the rails. Never had the noise come back.
                    Previous Ricoh Field Service Tech II - November 2017.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Beat me to it bro
                      • fireater
                        • Apr 2006
                        • 253
                        well after lubing it 3 times i ordered the Launa oil from Ricoh. we willl try it out
