adf 3030 (mpc2800 mpc2550). Pick up roller stays down
  • Mark Bbb
    • Jun 2012
    • 1662
    Hello,
    After i replaced the left hinge some 1,5K (DF count) ago, now the pick up roller stays down.
    When i perform an output check on the "transport motor forward" (sp6-008-005) the original stopper fingers (5) goes up and down very quickly...
    Strange is that it worked fine for a while...
    Anyone has a cleu?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: adf 3030 (mpc2800 mpc2550). Pick up roller stays down
    Take the back cover off. There's a solenoid in the back that has two actuators connected to it, one white, one black. One of those will have come off.
    Hit it.
    • Mark Bbb
      • Jun 2012
      • 1662
      T.M.:
      I just dis- and reasemble these area.
      The 2 actuators where and are in the whright position.
      I think there is a home position sensor faillure...
        • 37532
        Originally posted by Mark Bbb
        T.M.:
        I think that some junior tech did not reassemble the feed shoe properly.
        • Mark Bbb
          • Jun 2012
          • 1662
          Slim: feed shoe?
          I have surched on "shoe" in the parts cat, but no match
            • 37532
            Slim: feed shoe?
            It refers to the assembly that holds the pick up roller and feed belt. If it is not assembled correctly, it will not properly follow the the lift cam.
            • Mark Bbb
              • Jun 2012
              • 1662
              Slims:
              The shoe is fitted like a glove: it is positioned correct.
              Even without the original feed in unit (shoe?) the original stoppers go "tak tak tak"; up down - up down, realy fast!
              I'm thinking perhaps the DF main board has a failure.
              • Mark Bbb
                • Jun 2012
                • 1662
                Got it:
                The black/white plastic levers/actuators (rear) are tensioned with a black spring (vertical).
                Also the duplex juncion gate plate (rear) is tensioned with a black spring (horizontal).
                Don't mix up those springs...
