RICOH MP3500 TD Sensor Initialization
  • ryan416
    • Jul 2025
    After entering SP Mode and trying to do a TD sensor Initalization the photocopier prompts me for a 7 letter word before the "execute" button is available to select. Is there a generic 7 letter code or where can I find it?
    Thanks,
    Ryan
  • totoro
    • 568
    I believe it is asking for the batch number on the developer (top of bag )that you put in the copier.
    Totoro
    Totoro
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      • ryan416
        Ok I ran the TD Sensor Initialization then the Developer Initialization (note: this is a brand new copier out of the box), but I keep getting SC391 error (bad TD sensor connection/bad toner supply) - I'm I forgetting to do something to get this copier started?
        I just get blank pages when I try to copy something. Where is the TD Sensor located?
        Thanks,
        Ryan
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Might be a stupid question, but you did check to see if it has developer installed ryan416?
          New machine, td sensor error, blank copies... sounds like the dev unit is empty to me.
          • bostjanma
            This is a LOT no. of developer and it is on a uper side of developer case!
            • Polo-022
              • Sep 2007
              • 486
              I never had to install a brand new copier wich i have never seen it again. Do you really think that you can support this 'monster' ignoring what does TD means? Good luck...
              • Scott_Lewis
                • Mar 2007
                • 519
                [quote=ryan416;49466]Ok I ran the TD Sensor Initialization then the Developer Initialization (note: this is a brand new copier out of the box), but I keep getting SC391 error (bad TD sensor connection/bad toner supply) - I'm I forgetting to do something to get this copier started?
                I've had a few new boxes with this problem. Just reseat the developer. The connector on the back of the developer unit isn't making a good connection.
                If ya don't know where the TD sensor is, ya need more help than I can give you.
