mp c4503 white lines in copies, print jobs
  • gregm27
    • Mar 2018
    • 15
    hello and good day. I am looking for the definitive guide and steps for fixing white lines in copies and print jobs. I have tried cleaning the mag rollers with a piece of paper, but I can get these lines to go away
    • 37556
    Re: mp c4503 white lines in copies, print jobs
    Dirty laser shield glass or doctor blade gap.
    • gregm27
      • Mar 2018
      • 15
      Thank you, sir, I will try both.
      Has this happened to anyone, I clean the mag roller with the paper trick and the white lines on the copies move and appear on the paper at a different location?
      • Brianneoe
        • May 2015
        • 322
        We see this a lot on off lease machines that have been sitting around doing nothing for awhile, there are toner chunks that causes the developer to ball up and cause blockage at the doctor blade. If you remove the DV unit from the drum housing you should see it. I have dumped the developer out and tried to pick out the chunks but 99% of the time comes back. Best bet is to change out the developer unit with a new one.
        • fshead
          • 2376
          Moving the chips to the side will not fix it.
          i take an old newspaper and lay it out in a quiet part of the office and dump the dev unit
          onto it.
          I then vacuum any of the nasty bits still in there,should be very nominal.
          I take a few pieces of 11by17 paper and a plastic flour sieve and gently
          drop my dev onto it..and sift out the clean onto the paper.
          I would check all filters and fans to make sure machine is not
          running too hot..
          If YOU COULD ADJUST VENTILATION FANS TO STAY ON LONGER THAT CAN HELP WITH
          future issue,machine must breathe..
          • gregm27
            • Mar 2018
            • 15
            I want to thank you all for these suggestions, you have all been so helpful. There was a stubborn white line I could not get rid of no matter how much I cleaned the roller, tried developer, etc, etc. I could get rid of the other white lines, but this one just would not go away. I went into SP mode 3701 and reset the PCU aand dev unit (option 1 then # key) and it got rid of that last white line that would not go away.
            This was my first thread but I have been a lurker here for a couple months and have learned so much from you guys, I appreciate all the answers you have written up here. Thank you.
            • davel
              • Oct 2011
              • 1107
              It will come back.
              • logrady2331
                • Feb 2011
                • 301
                You HAVE cleaned the charge rollers, right?
                • skinnyb
                  • Jul 2008
                  • 291
                  Yep. Changing the dev unit is the only fix. And make sure ventilation is at max. Too much heat or extended sitting in high humidity and/or temp environment will make developer clump up.
                  Originally posted by davel
                  It will come back.
                  Sent from my VS987 using Tapatalk
                  • davel
                    • Oct 2011
                    • 1107
                    Dirty charge roller will give dark line, not white.
                    • ccchuah
                      • Mar 2009
                      • 158
                      Filter out the developer will get rid of the white lines, the developer contain some of the dirty particle the block cause the white lines
