Need Some Comments and Suggestions Regarding Copiers
  • marilynliddell
    • Aug 2025
    Hi i would like to ask from you guys some comments or suggestions regarding copiers. What models of copiers can you suggest that is better or best depending on your experience with the machine. Like for example, Canon or Bizhub or other brand that you can recommend. Also may i know their advantage and disadvantage like for example on pc connectivity, if they can connect on windows or mac, what parts are commonly replaced. Any ideas and suggestions would be gladly appreciated. Upon giving some ideas and models of the machine, i will do the rest of the research.
    Thank you very much.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: Need Some Comments and Suggestions Regarding Copiers
    Best copiers are what the tech responding, works on the most. A company Xerox tech loves Xerox. Some techs work on several brands, like myself. I am Xerox trained, but don't like to work on them. The copier you need also depends on the type of work being done, and the volume.
      • 30390
      Black copiers Kyocera, Color Konica, Ricoh Canon all do well
      Printers HP color and black and Kyocera black printers
      Don't over buy pricing is based on speed and volume
      pick what you need.
      Kyocera makes some great small Black machines very fast you can just add paper trays if you don't need 11 by 17
      Kyocera and Konica included PS Ricoh and Canon it's usually an option
      you will need PS printing from Mac OS
      Scanning all machines will scan to file, scan via ftp,and email. Scan to MacOS has become a problem do to Apple OS changing
      protocols IE smb samba and removing ftp. Scan to email would be the best option on MAC
