Aficio MP C2500 Black toner pump
  • Arkynsaw
    • Oct 2017
    • 54
    I just ordered one of these from my vendor , when I opened the box there was a yellow substance on the pump and inside , just a small amount , it looked like yellow toner , suspect it may be a used part . Has anyone seen this and knows if its a lubricant of some sort or if I am right to suspect that the part may be used and was cleaned up a bit to look new . I do not remember seeing this kind of lubricant before , but my vendor swears that thats all it is . The part was in a good clean box that looked like a genuine Ricoh part . Thanks in advance , Ark .
  • copyaction
    • Oct 2007
    • 991
    Re: Aficio MP C2500 Black toner pump
    Last one I got was the same way and it was new and worked fine
    • Lagonda
      • Aug 2008
      • 1649
      yes, they use yellow as lubricant when they build pumps.
        • 37495
        Also for testing.
        • skinnyb
          • Jul 2008
          • 291
          Yep. All of mine come with yellow stuff in them. The D029 ones too.
          Sent from my VS987 using Tapatalk
