MPC4500 gear pump tone problems
  • justinchan
    • Jun 2018
    • 8
  • fshead
    • 2376
    Re: MPC4500 gear pump tone problems
    i get the feeling you are not a tech?
    You need to search previous posts as toner pump issues are not new to these models
    • sandmanmac
      • 3981
      Originally posted by justinchan
      hi all
      after i change the yellow pump the back of the machine sound loud and sound like gear scrape. than i try change other thing aswell .
      any body have idea what is problem please ?
      Before "Service": No noise
      After "Service": Scraping noise
      ....so it never crossed your mind that maybe (just maybe) you have installed it incorrectly?
      And what "other things" did you try to change?
      • ridgemill
        • Sep 2017
        • 190
        hi all
        one day my mpc 4500 suddy can not detect the yellow toner than after i change the yellow pump the back of the machine sound loud and sound like gear scrape. than i try change other thing aswell .
        it come up can print black and white but when print colour it miss yellow colour, after i try few time , the machine can detect yellow toner but come up other problem the machine can not print anything . when i press “ clear mode ->107 ->c/s ” it just have COPY sd and print sd can do anything
        thanks so much !!
        What is the part number of the pump? And, is it a second hand part or new?
        The number should be B223-3252.
        Other causes of noise around this area is the drum and/or dev unit.
        • justinchan
          • Jun 2018
          • 8
          yes you are right i am not a tech, i just a emplyee who try to fix the printer, i mean try
          actual i had a MPC2000 aswell , i try to take the pump from mpc2000 it look the same as mpc4500
          i try to replace the pump , but machine dont work , when i switch on machine the gear scrape noise it come out
          i check the black that is what i found out it show on the pictures that part it won't turn .
          holp you can help me
          • justinchan
            • Jun 2018
            • 8
            sorry , may i show you the photos and could you please tell me what part is it ?
            thanks very much
            • justinchan
              • Jun 2018
              • 8
              please let me show you the pictures
              i apologize my english let you feel confuse.
              but i will try my best explain what happening and i so grad have your guys helping me , thanks
              • floody
                • Mar 2017
                • 37
                theres a white plastic clip missing for that clutch, have you taken it off? theres no need to touch that when changing the toner pumps
                • fshead
                  • 2376
                  looks like your sherboygan modus is shot...
                  • UNICORNico
                    • May 2018
                    • 308
                    yes you are right i am not a tech, i just a emplyee who try to fix the printer, i mean try actual i had a MPC2000 aswell , i try to take the pump from mpc2000 it look the same as mpc4500 i try to replace the pump , but machine dont work , when i switch on machine the gear scrape noise it come out i check the black that is what i found out it show on the pictures that part it won't turn .
                    [ATTACH=CONFIG]40139[/ATTACH][ATTACH=CONFIG]40140[/ATTACH]
                    I think you're confused and you're not changing the toner supply pumps. But another piece ...
                    Image of Toner Pump:
                    I would appreciate it, explain concretely which piece has managed its change / repair and take into account that as indicated by other technical colleagues, a "white piece" that holds the main axis of that engine is missing.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                      • 37484
                      [ATTACH=CONFIG]40144[/ATTACH][ATTACH=CONFIG]40145[/ATTACH]
                      That is the clutch for the yellow toner pump. With that clip missing, no wonder its making noise.
                      • justinchan
                        • Jun 2018
                        • 8
                        yes i take it off (just forgot put it back when i take the picture), but the promble is when i switch on it stuck and noise .
                        • justinchan
                          • Jun 2018
                          • 8
                          thanks your reply , in this pitcure i mean this part stuck when i turn on the machine , and around this area so noise , sound like there are two gear one is turning and other stucked and scratch each other .
                          • justinchan
                            • Jun 2018
                            • 8
                            [ATTACH=CONFIG]40162[/ATTACH]
                            thank you show the picture , yes i change this part already and that is what the noise start .
                            the photos what i show is ,after i chaged the pump ( form my other printer mpc2000) and i switch the machine this part stuck and noise ,
                            the white part is missing beacuse when i take photo i forgot put it on.
                            PS:thank you show the picture make me easyer understand .
                            • justinchan
                              • Jun 2018
                              • 8
                              thank you your reply , i dont understant what is mean "sherboygan modus" and i try google search , i cann't find any picture can you explain more please ?
                              thank you your patience
