Mp5055 drum/dev unit drive unit noise
  • davydoodle
    • Jun 2018
    • 17
    Any body seem this, with the pdcu out of the machine?
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Mp5055 drum/dev unit drive unit noise
    These machines have a shared drum/waste toner motor and a separate dev motor.
    If you're running the motors in output mode and still getting a noise it might be an indicator that the motor itself is shot.
    Just as a test...replace the waste toner bottle first.(cheaper option)
    • jonhiker
      • 661
      I have had this same issue and it is usually the waste toner bottle
      • DH1980
        • Mar 2009
        • 52
        Have also seen waste bottle make noise. The machine sounds like a motor but it is the waste bottle.
        • davydoodle
          • Jun 2018
          • 17
          Yep, it was the waste bottle...
