MP4001 VOIP fax
  • tufbnme
    • 493
    MP4001 VOIP fax
    Can someone tell me if there is a fix for poor communication and slow receiving of faxes on a Ricoh MP4001. Customer has digital phone service.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MP4001 VOIP fax
    VOIP sucks for faxing!! slow down the tx and rx baud rates, 9600 or slower, increase the modem volume, increase the page reconstruct time as well.......... fax machines are designed for a good old analog phone line!!!!!!!!!!!!!!!!!!
    Mystic Crystal Revelations
    • driving lots of miles
      • Jun 2016
      • 397
      Re: MP4001 VOIP fax
      I agree, the above is about the best you can do. Faxs are 80's technology, but there does not seem to be anything else that is as secure, especially for Hospitals, medical clinics and Doctors offices.
      • mincopier
        • Dec 2015
        • 289
        Re: MP4001 VOIP fax
        Fax technology actually goes back to the 50's.
        But yes fax is analog and does not play well with a digital phone line. All that can be done is to slow it down.
        • guitar9199
          • Sep 2016
          • 1100
          Re: MP4001 VOIP fax
          Another thing to do is turn off ECM. There's a tech bulletin on Ricohs using VOIP for faxing....I'll see if I can locate it.
          • guitar9199
            • Sep 2016
            • 1100
            Re: MP4001 VOIP fax
            Found it...
            • Methedor
              • Nov 2016
              • 69
              Re: MP4001 VOIP fax
              For anyone else having this issue, or the OP if that issue wasn't resolved:
              The RX rings can also be an issue, encountered that with one client where the RX rings has to be set to 1 so the rest of the system didn't mess with it.
              SET RX RING COUNT: (FAX SP mode) SP 2-103-007
              • logrady2331
                • Feb 2011
                • 301
                Re: MP4001 VOIP fax
                Every VOIP provider has an ATA filter for fax machines. Should be around 150.00. Problem solved.
                • Methedor
                  • Nov 2016
                  • 69
                  Re: MP4001 VOIP fax
                  "Every VOIP provider has an ATA filter for fax machines. Should be around 150.00. Problem solved." - logrady2331
                  I am uncertain as to what you are specifically referring to. I assume an ATA filter is a jack? Thank you, my encounters with VOIP for Fax have been rare, but eventful when they happen.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    Re: MP4001 VOIP fax
                    I usually default mine to two....just to avoid the "Wrong number-one ring" calls, but good catch!
                    • guitar9199
                      • Sep 2016
                      • 1100
                      Re: MP4001 VOIP fax
                      It's the old "DSL Filter" trick!! (ATA= Analog Terminal Adapter)
                      When people use DSL, they also have to use a filter to block the digital "noise" of the DSL portion of their signal from reaching their telephone line. This helps isolate just the "voice" portion of the signal for the phone. Some people have had success with it, but I've found it only to be helpful on "noisy" VIOP lines.
                      I usually just...
                      Slow down Baud Rate (9600)
                      Turn off ECM
                      Use default G3 protocol
