Parting out a mpc2500 and mpc3500
  • fshead
    • 2360
    hi
    I never worked on these two models but can pick up a few used for cheap to part out.
    I understand the drums can work on the mpc2800/c3300/c3501/c3502.
    ANd need to know does the ITB unit swap over too?
    I know fusers are all different and the toner pump too.
    thanks
  • nmfaxman
    • 1702
    Re: Parting out a mpc2500 and mpc3500
    Compare part #s. If they don't match they can't crossover.
      • 37365
      There is a post on the forum that list the changes to make to use the drums in other models. The ITB units may not fit but the belts are the same across most models. As for toner pumps, you are better not using used pumps.
      • mikadonovan
        • May 2008
        • 2931
        They would not even fit the models he indicated.
        NEVER ASSUME ANYTHING
        • fshead
          • 2360
          i found out the hard way buying a few on ebay.
          I have a bunch of older used machines that i will upgrade end of year so i am just trying to
          keep costs down till then..
