Mpc4503 white stripes on yellow print
  • Codex
    • May 2008
    • 667
    Hello i have a strange problem with a Mpc4503... If we print in full color there is a white stripe in the middle of the paper, turned out to be the yellow development unit, tried to clean the doctor blade with my tool but nothing. Swapped the yellow development unit from another machine..... And i have exact the same problem!...... At this point my question.... Can i be an electrical related problem? Or is this a known issue on this machines that the development units have this kind of problem? The laser protection glasses are clean...
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • qbert69
    • Mar 2013
    • 1152
    Re: Mpc4503 white stripes on yellow print
    Clumped toner or contaminant in development unit causing void line on mag roller! Separate drum & dev units, rotate mag roller, look for toner void line. Use a piece of mylar to breakup/release contaminant. Keep rotating & cleaning until void is gone. [emoji41]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
