Intermittent failed to connect to smtp server
  • scot88
    • Jun 2012
    • 20
    [Error Code] Intermittent failed to connect to smtp server
    I have a MP C5501/D089 with intermittent scan to email "SMTPC: failed to connect smtp server. timeout. ERR:" on the log. I did an infinite ping on both the machine and wall jack and don't see any dropouts, it always works when I'm there. They have another machine on site that is working fine, but next door to the server room. Thinking it might be a traffic thing? any ideas?
  • jhalfhide
    • Apr 2015
    • 451
      • 29988
      Re: Intermittent failed to connect to smtp server
      Use the hard ip address of the smtp server
      • scot88
        • Jun 2012
        • 20
        I did make sure the DNS was the same, in fact made sure all the setting were the same, but haven't tried the ip of the mail server.
        Thanks, Ill give it a try.
        • scot88
          • Jun 2012
          • 20
          Oh, print doesn't seem to be affected, I asked, everyone says it prints fast no delays.
          • jhalfhide
            • Apr 2015
            • 451
            • NeoMatrix
              Senior Tech.
              • 3513
              Like you said traffic could be causing latency in the network.
              Try Swapping DNS1 IP with DNS2 IP....
              Eg.
              DNS1 192.168.1.100
              DNS2 192.168.1.200
              ----------Swapped ----------
              DNS1 192.168.1.200
              DNS2 192.168.1.100
              I assume your customer is not using a Safe Site DNS Server.
              Such be the case, the Safe Site DNS or Family DNS settings will block explicit or hacker web/email addresses by default.
              • Mark Bbb
                • Jun 2012
                • 1662
                You write:
                "I did an infinite ping on both the machine and wall jack and don't see any dropouts, it always works when I'm there"
                That is because they are open sources.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  check DNS and operators email address
