Developer in the PCU gears
  • xcopier
    • Aug 2015
    • 36
    Recently, i noticed that developer powder is making it to the gears of the PCU of our MP2000.
    This creates rough, grinding noises and worn out some of the gears.
    What could be causing it?
    Thanks in advance for your inputs.
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Developer in the PCU gears
    Age and wear and tear on parts. Best bet is to replace the lower dev unit or the mag roller gears will get eaten as well, eventually it won't work at all or will seize.
    • sandmanmac
      • 3990
      Generic Dev?
      It's caused me issues like this in the past
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        This often happens because the developer unit was not replaced.....just the developer/starter. When we rebuild the pcu we replace the drum,developer, and starter to ensure reliable performance. Replacing all those parts is expensive though, so many customers just install the Type 1027 PCU and run the developer calibration. While that works and lasts quite a while, and is very affordable, those 1027 drum units don't last as long as they normally would because the dv unit gear drive is slightly different.
          • 37637
          Normal wear and tear on bushing in the bushings the development unit. Truthfully it is only normal if you try to push the pm cycle or use third party developer. Depleted developer gets into the bushings which further wears them.
          • COPIERMAN
            • Jun 2009
            • 560
            we rebuild units all the time. Replace seals and gears and you have to look at auger shafts it worn you have to replace lower unit. i have ran oem devlp and toner units and they last as long on the generic stuff. Other things is foam seals wear out so at some point you have to replace lower units or mag holder assy. i buy devlp powder from copylite and toner and seals and gears from china.
            • Mark Bbb
              • Jun 2012
              • 1662
              I only replace development units when this issue occurs.
              Pouring developer in the development tank needs to be done without spilling, thus very carrefully.
              Transport a mp2000 could case this issue too.
              • MitchD
                • Oct 2012
                • 164
                This was our normal practice as well. Seemed to work fine and almost 99.9% of the time eliminated the dev working in the gears problem.
                But Ricoh has recently discontinued the Type 1027 PCU. We are out of stock and currently looking for an (gasp) aftermarket solution for our customers that just flat refuse to upgrade to a copier built in this decade.
                Good luck everyone
                "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                • copyaction
                  • Oct 2007
                  • 991
                  • 8T2
                    • Aug 2015
                    • 257
                    We scoop out about a tablespoon of developer, from day 1 on installation. It really works and the loss in yield is negligible. Copy quality issues annoy users less than a machine asking for toner when the bottle is full and sitting with a seized dev gears...especially if they already waited a day for the toner delivery just to have toner spilling everywhere and making a mess when they try to change the toner
                    Sent from my ALE-L02 using Tapatalk
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      Good luck everyone
                      Sadly even that won't save you. The MP2553 series launched in 2013 still uses the same style development unit as the MP2000, slight differences but same operational theory.
                      It wasn't until the MP2554 that they threw out that designed and make something new. Even the the MP2501 is almost the same being that it's mostly an upscaled Mp301
                        • 37637
                        Good luck everyone
                        For over a year, Ricoh has been shipping rebuilt PCU's labeled as Type 1027R. This is most likely due to the the fact that since the introduction of the MP2510/3010 many techs have been using Type 1027 PCU instead of rebuilding the 2510 PCU. Those needing to replace a Type 1027 PCU with a PCU for a MP 2510 and then rebuilding every 60K.
                        • copyaction
                          • Oct 2007
                          • 991
                          also been using the type 1027 pcu in the 2851 series. And it can be used in the 2852 series with a slight modification.
                          • xcopier
                            • Aug 2015
                            • 36
                            In our country, we are still able to buy replacement parts for our MP2000 and 2018D. Parts that often wear out such as development gears, transfer roller gears and the gear between the registration clutch and the main gearbox are still available.
                            Entire PCU's are still available for the equivalent of about US$120.
