Ricoh MP C300 C400 fax switch
  • gideon
    • 283
    If you have the part number for the fax switch, the switch on the control panel under the display, please let me know.
    Re: Ricoh MP C300 C400 fax switch
    those come as whole board assemblies... look in your service manual for the complete assembly part number
      • 37628
      You might want to ask HiTech board repair to see if they can help you.
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        If you are wanting a part# for the switch actuated by the Fax key button..... you need to order the control panel unit or maybe just check the solder joints on the existing switch. Those switches should be available from any electronics supplier. It's a really common push button switch. That machine is from 2011.....Seems like a lot of trouble to go to when you can pick up a super low meter unit with a perfectly good control panel at the one of the copier wholesalers for next to nothing. Way cheaper than buying a whole control panel.
        • fshead
          • 2378
          i bam assuming you want the actual switch not the button mounted on control panel.
          I use to scrap one panel from my "junk pile" and desolder the most unused switches first using a desoldering iron.
          When i had a switch get flakey or just go bad i would solder on a new one.
          I am lucky on most machines i have out there i have a complete parts machine when needed.
          I might even have a whole control panel for that model too.
          • gideon
            • 283
            I found the switch, I needed only the button on the control panel, when it will arrive I'll post the part number.
            • gideon
              • 283
              For future search Ricoh part # M026 1543 (keytop : Fax)
              Thanks to all
