Mpc3001
  • jathrow
    • Aug 2017
    • 1
    [Error Code] Mpc3001
    Mpc3001 Error Sc204.
    Check harness , replaced polygon motor and reset SC code but the error re-appear. Could it be the drive board and what else can I do.
  • sandmanmac
    • 3983
    Re: Mpc3001
    The previous version of this model (C2800/3300) had an issue that when the Polygon motor went (SC204), it also took out the BICU, so you would have to replace the 2 as a set. I can't find any documentation about it for this model, but it sounds like the same thing.
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: Mpc3001
      Check the green earthing strap on the side door harness, it could be broken. Also there are two springs either side of the PTR assembly that move it backward and forward, one of those coming off can cause this code.
      Hit it.
