Wrong PCDU" message in 5th station proc7100x
  • en.
    • Jul 2014
    • 124
    hi every one
    have a good day
    i have problem with proc7100x ...the customer tray to replace withe color 5 with clear but and he follow the instruction the field service manual also ther is video from Ric oh guide him how to replaced the 5th color but now the machine not goes ready and give him this massage
    (The error message "Set PCU clean Unt/Wrong PCDU) :
    i do this action
    :replaced with Noe 5th color
    replace all component (charge & cleaning ) but its give me failed ...
    any one can help me
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Wrong PCDU" message in 5th station proc7100x
    Originally posted by en.
    hi every one
    have a good day
    i do this action
    any one can help me
    Ricoh actually distributed some bad units and later released an advisory about the problem units. I'll see if I can find you the pdf.
    • blazebusiness
      • 1250
      Here you go:
      rfg WRONG PCDU Message.pdf
      • en.
        • Jul 2014
        • 124
        hi my friend
        thanks for your responding ...i know this pdf i sawand i know this RTB ...this RTB talking about develoment unit in fourteen 2014
        but now all my development is in 2016
        so just i want to know what the solution ?
        • en.
          • Jul 2014
          • 124
          Originally posted by blazebusiness
          Here you go:
          [ATTACH]40128[/ATTACH]
          hi my friend
          • blazebusiness
            • 1250
            hi my friend
            Even if you did not get one of those bad 2014 units----you may still have a similar issue. The unit has a chip that stores the color information.This chip is blank until installation occurs, and the machine writes the information to the chip upon installation.
            Either the part you got didn't have a blank chip or the 5th station installation procedure was not followed correctly.
            After installing the 5th station for the new special color.....you have to log into user tools and go to adjustments for skilled operators. Select machine image quality. Select Adjust image density/dems. Then select DEMS and hit execute.
            Did someone forget to do this step?
            • en.
              • Jul 2014
              • 124
              yes .. i am sure some one forget one of step but now i want to solve the problem ..what should i do to make device reading special color 5th station ??
              • Sashko
                • Oct 2009
                • 110
                Please mail me if you want to know how to solve this issue in the field without change anything.
                • Sashko
                  • Oct 2009
                  • 110
                  Use this sequence to return the machine to normal operation:
                  1 - set to "4th" in SP3-106
                  2 - switch Off the machine
                  3 - change the 5th station to colour was before
                  4 - switch On the machine
                  5 - change setting to "5" in SP3-106
                  6 - set the settings according to colour was before in SP3-107-001/002/003 (see table below)
                  6 - reboot the machine
                  This sequence of operation clear the condition "Set OPC clean Unt/Wrong PCDU(S)"
                  SP3-107-XXX White Clear Neon Yellow Neon Pink
                  001 3 2 2 2
                  003 2 1 3 4
                  003 2 1 1 3
                  • mrwho
                    Major Asshole!
                    • 4299
                    001 3 2 2 2
                    003 2 1 3 4
                    003 2 1 1 3
                    Sorry for digging out this rotten corpse of a thread, but just to say this one saved my proverbial ass. Thank you!
                    Mascan42
                    Ibid
