Transfer Belt (MPC5502 go to MPC4503)
  • UNICORNico
    • May 2018
    • 308
    [Jamming] Transfer Belt (MPC5502 go to MPC4503)
    Dear Technical Partners:
    I have a question in case someone has tried it or they know if this question has already been raised in the forum (on my own, I have not found it) on the following one.
    In case of emergency, can you use the "Transfer Band" of an MPC5502, in an MPC4503 ??? Obviously not the unit, but what the band itself is.
    A greeting.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Transfer Belt (MPC5502 go to MPC4503)
    A greeting.
    I believe they slightly downsized the ITB unit in the 03 series----so that would be a no. Belt from the 03's should work ok in the 04's though.
    • skinnyb
      • Jul 2008
      • 291
      What he said. Belt on the 03 and newer is much shorter as the entire unit is much more compact and "flat" rather than triangle shaped.
      Sent from my VS987 using Tapatalk
