af 3035 panel
  • Gab
    • Aug 2015
    • 677
    af 3035 panel
    i want to calibrate the op panel.i get in menu but when is says to point with a point tool to a small cyrcle upper left and touch this cyrcle with a pen or something else nothing happerns ' normali a little '+' appears' .
    any idea what to do.
  • Zeldaman
    • Mar 2011
    • 946
    Re: af 3035 panel
    Hi there!
    Change the touch-panel pn B3125222.
    Greetings...
    • 8T2
      • Aug 2015
      • 257
      Re: af 3035 panel
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      Agreed...touch panel buggered
      Sent from my ALE-L02 using Tapatalk
        • 37628
        Re: af 3035 panel
        Nine years ago Ricoh was having a problem on some new or nearly new machine machine. There basically 2 models of the the the touch panels. If you have a psrts maching with the same size panel try replacing.
        Ricoh has identified a breakdown in the adhesive which establishes the electrical conductivity
        between the Touch Panel and the LCD. The initial projected failure rate is low, however the
        failure rate increases as the machine ages and is affected by certain environmental conditions.
        This failure may be intermittent or continuous and may be exhibited by the following symptoms:
        1. The Touch Panel does not respond.
        2. The Touch Panel does not hold calibration / adjustment.
        3. Fax or Scan to Email may be sent to the incorrect destination.
        • Gab
          • Aug 2015
          • 677
          Re: af 3035 panel
          can i use touch panel from af 2045 in this machine.
          • wilez
            • Jan 2011
            • 55
            Re: af 3035 panel
            No! different touchscreen. As a swap use MP3035 or 3045. or try the mp3500/4500 panel
            https://t.me/pump_upp
            • Gab
              • Aug 2015
              • 677
              Re: af 3035 panel
              Just to inform
              I replaced touch panel with one from 2045 and it works perfect!
