Re: Ricoh MP C4504 and SP C842/840
Yup PCDU's and transfer works, been using them for ages.
With the PCDU all you need to do is remove the TD sensor and harness off the old one and place it on the kit and when placing it in the device the front cover wont fit without trimming it but I leave them off completely
If you are fitting it in a 6004 its fine, if your fitting it into a 4054 and lower you need to remove the lube bar and tension it back up as the tension is already released from new
Transfer unit is a straight swap, only changes I use the cleaning unit transfer waste off the old one, also you must remove the entire cover off the kit transfer as it wont fit and the original cover also wont fit as the shaft that locks the K PCDU in is very long
Fuser I really couldn't be bothered working out what requires modification but if someone does it please let me know
Note the Lube bars are not as long as the individual genuine PCU but they last the same length of 400 K for black and 270 K for colour
Sent from my VS987 using TapatalkLeave a comment:
Fortunately the transfer belt lasts forever.
Apparently you have never had Sally Sexratary gouge one with her engagement ring.Leave a comment:
However the ITB looks different to the MPCxx04 ?
