Ricoh MP 6002 SC 623
  • semi
    • Sep 2008
    • 193
    [Error Code] Ricoh MP 6002 SC 623
    Hi,a repeating SC 623 error code,manual suggests pf board/bici.
    Machine will randomly throw code ,even when idle.Tried a new pf board, FU105 on power supply,
    Checked tandam tray for shorts etc-anybody else seen this before I throw big dollar on a bici-cheers
    Re: Ricoh MP 6002 SC 623
    you could have line power problems... check wall voltage
    • DRichard
      • May 2008
      • 482
      Check for other appliances / equipment on the same circuit, especially anything that draws a lot of current and cycles on/off periodically just as the fuser in a copier does. Likely culprits are refridgerators or electric space heaters. If this doesn't pan out you should put a monitor on the line to isolate power spikes and drops.
      "Enjoy every sandwich."
      -- Warren Zevon
      • apump
        • Mar 2009
        • 160
        had 3 of these (6002) doing this. I replaced the bicu and haven't seen code since
        • semi
          • Sep 2008
          • 193
          Re: Ricoh MP 6002 SC 623-Fixed
          BICI seemed to have fixed it,fitted monday,checked today all ok,cheers everyone
          • flexrub1234
            • Jul 2012
            • 2
            Customer is 2 hrs away. They call at least once a month.
            SC623, but by the time i get to client the code is then SC543
            I clean the cruddy thermistors and reset code. all returns to normal.
            The only thing the user does is re power the unit. Works sometimes.
