mpc6004 smart panel adjust
  • dhg
    • May 2011
    • 26
    how do i adjust sensitivity on this smart panel, since C1993 went away ?
    thanks
    • 37491
    Re: mpc6004 smart panel adjust
    thanks
    I am retired and haven't worked on the 04s but on the 03 SOP I got into it using the classic copy function screen.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      For the smart op V2 panels you have to go into screen service mode. This is done the same as going into SP mode normally on this machine but instead of hitting the C key at the end you will hit the pound key (#) twice then hold down the C key for a few seconds. Once you let go it should go into panel service mode. Scroll down to "Screen device settings" and you'll get a menu of diagnostics including screen calibration.
      If you try to go to fast when hitting the keys to go into service mode the machine may not pick them up.
