Expansion box on another machine
  • xcopier
    • Aug 2015
    • 36
    Hi,
    Our Aficio 2018D had retired and it had this expansion box that gave it network connectivity.
    Can i use this expansion box on our MP2000 and hopefully give it print and network capability? The MP2000 is currently on a copier only configuration.
    Thanks for your inputs.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Expansion box on another machine
    You wish to use a USB cable to Ethernet cable conversion box; much the same conversion box as some of the old HP models?
    Firstly... the Ricoh MP2000 should have Ethernet cable capability as factory standard = networking.
    Why would you wish to convert the MP2000 Ethernet from USB?
    Sounds like the MP2000 is missing the network SD print/scan card from slot 1.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      Originally posted by xcopier
      Hi,
      If you are talking about something that was installed *inside* the machine then no, those options are machine model specific. If you want to upgrade your MP2000 from basic to print/scan ability you would need to find a Printer/Scanner Unit Type 2000 Kit the manufacturer code for that is
      413572
      Good luck finding one though!
      • xcopier
        • Aug 2015
        • 36
        413572
        I am referring to the big box that is attached to the BICU board. The one with SDCARD slots and usb/network cards.
        The service manual simply referred to it as MFP expansion component box.
        I did some digging and found there are are Printer / Scanner Unit SDCARDS for specific models. And there are those being sold online that's for an MP2000. Would I be able to use the box from the 2018 if I were to replace the 2018 SDCARD with an MP2000 SDCARD?
          • 37652
          That is whatsturmtrooper was referring to.
          • fshead
            • 2378
            Why would you even buy a used machine "10 yr old" without print?
            Unless it was free..
            • sandmanmac
              • 3990
              No.
              There is NOTHING related to electronics that is interchangeable between the 2 machines.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                As EVERYONE ELSE stated...you can't take the Controller box from the 2018 and slap it into the MP2000.
