Aficio 3030 print scan unit
  • Mark Bbb
    • Jun 2012
    • 1662
    I know it's an old one.
    1. Have put in the SD print/scan card, nore print nore scan function available.
    2. Have swapt a controller board (from a 3025) (with the print scan unit SD card) to the 3030 (after swapping the 2 eproms):
    error sc995. Then did a HDD format all, no good.
    3. without HDD sc876 and with the original HDD (from 3030) still sc995...
    Anyone?
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    Re: Aficio 3030 print scan unit
    The 3025 and 3030 use different Controller PCB's. Your SC995 is a Controller board error.
      • 37628
      It sounds to me like you did not properly install the Printer/Scanner option. Most likely you install only the SD card. If you were to have looked at the service manual you would have seen that kit from Ricoh includes a 256MB DIMM to install on the controller board, brings the total memory up to 512MB which the option needs to work.
      • 8T2
        • Aug 2015
        • 257
        Also NIC has to be enabled if I'm not mistaken
        Sent from my ALE-L02 using Tapatalk
        • sandmanmac
          • 3990
          ...And also not informed us if it was previously working and has failed, or he is just trying to install the feature from scratch. I hate that!
            lack of information from MOST posters is a big problem ( you tell them and sometimes they don't even update the info)... then most times they don't even take the advise
            clearly people don't read the site rules
