Sp5300 SC533
  • davydoodle
    • Jun 2018
    • 17
    Sp5300 SC533
    Swapped fuser on this little jem of engineering, ng. power supply maybe??
  • guitar9199
    • Sep 2016
    • 1100
    Re: Sp5300 SC533
    Did you go into service mode and clear the error after you swapped the fuser unit?
      Re: Sp5300 SC533
      there is an SP mode you have to change to clear the fuser code... did you do that change? IF NOT... you will get the error code. The fusers do NOT have a reset fuse in them.
      • davydoodle
        • Jun 2018
        • 17
        Re: Sp5300 SC533
        Yep did that, failed...
          Re: Sp5300 SC533
          you aren't trying to use a fuser from a compatible PRINTER are you? I know the only diff on some fusers like that, is the jumper harness at the front of the fuser.
          • guitar9199
            • Sep 2016
            • 1100
            Re: Sp5300 SC533
            If you're installing a "Donor" fuser, check the thermistors. I've seen some throw SC 5XX codes just because they were caked with old toner. Clean them, reset the code again, and give it a test.
            • davydoodle
              • Jun 2018
              • 17
              Re: Sp5300 SC533
              Brand new out of the box, lamps good, book says try power supply
                • 37533
                Re: Sp5300 SC533
                Brand new out of the box? Has your boss called Ricoh yet for out of box failure replacement under warranty?
                • fshead
                  • 2376
                  Re: Sp5300 SC533
                  do you have a working 2nd machine to test the "brand new one"?
                  did you meter the lamps and such?
                  • Tecnicopia
                    • Jun 2015
                    • 31
                    Re: Sp5300 SC533
                    Did you connected the small connectros on the right side at the back, near the power plug?
                    Did you enter the SP to move the gear of the pression roller to the position to attach the fuser?
                    Check this.
                    Enviado desde mi Redmi 4X mediante Tapatalk
                    • davydoodle
                      • Jun 2018
                      • 17
                      Re: Sp5300 SC533
                      Was a bad new fuser from a sealed box, lamps tested ok...QC strikes again
